Subject twitching during Vray RT sequence render. Problem happens while using GPU and CPU. The problem goes away when rendering with VRay Adv.
Software used: 3Ds Max 2017 and Vray 3.6 for 3ds Max.
See 8 sec video displaying the problem at:
I believe similar problem is described in this post on this forum:
“turbosmooth and parenting issue on VrayRT” posted on13-11-2016, 10:16 AM
Thank you for your help in advance!
Can you share the scene with our support? It looks like an issue we’ve fixed in V-Ray Next but it would be best to check it.
Yavor
i can definitely share it. I am new to the forum, could you tell me where to send it, is there an email address i can email the file to?
thank you for your quick reply!
Welcome to the forum
You could send the scene to support@chaosgroup.com
Or if it is small and you don’t mind sharing it publicly - you can also attach it straight here in the forum.
i tried attaching in, but keep getting an error “Invalid File 38 Absentia02.max”
if there is a better way, i can absolutely share it here
fyi, i emailed the file to the address you provided. thank you for your help!
i re-rendered the scene in Vray Next and the twitching is gone.
