Vray RT antialiasing
I would like to know what parameters are involved in the vrayrt calculations.
For example on vray manual I readed that antialiasing has to be disabled when I use the progressive path tracing rendering method.
With VrayRT enabled when I change every single Vray parameter VrayRT restarts the rendering…why?
If I switch from lightcache to Bruteforce or I change parameters that VrayRT doesn’t use the render restarts…
Would be nice to lock all the parameters that aren’t involved with VrayRT.
Cheers
Yes, this has already been pointed out and we will look into it. The parameters that affect the RT are listed here (in the render settings from the standard v-ray renderer section):
