Vray RT for 3dmax 2011?
Can I install vray-RT1.5 sp1a on 3dmax 2011?
Thanks to all
no, i don´t think so. but vlado wrote that there will be a release of rt for 2011 this week…
ok
.thanks to all
Yes, you can. There’s a .dlr file out there that allows it to run in max 2011. Not sure where I saw it. Do a google search. Or you can just wait until the max 2011 version is officially released, but there are plenty of people already using sp1a with 2011..
Actually you can use RT Sp1a just fine with 2011. You only have to use V-Ray SP4a instead of SP5.
isnt there an RT section of the forum for these posts? not trying to be rude or anything its just that it the forum gets cluttered with the wrong topics
It can be used with SP5. I’ve seen it done. Just requires that updated .dlr file dropped into the vrayplugins folder under Max 2011 > plugins. But unless you have some burning need to use SP5 with 2011, then yeah, SP4a or waiting is the easiest alternative.
