VRay RT GPU Baking?
Hello Logan,
I misunderstood your question the first time. Sorry about that. Thank you for the information and the screenshots provided. They were most helpful.
I see you are trying to use projection baking, but unfortunately that feature is not supported on the GPU yet.
The GPU currently supports only standard texture baking.
As for the second part of your question, you are correct. The internal 3ds Max render elements are not supported, so outputs like the HeightMap do not work with V-Ray.
You can use all of the V-Ray specific render elements, though.
