Vray RT not saving image
I am having problems with saving on Vray RT.
I am on Vray 2.501 3ds max 2015 Quadro K5000 using Cuda Win 7
I cant render images to disk form the Vray Frame Buffer.
If I disable Vray frame buffer and save from the max render output It saves with a solid alpha channel.
If I render from Vray Adv it behaves as expected.
Any ideas?
Nomad
This is a bug which has been fixed for the next official release.
Until then you can use 3DSMax native file output as a workaround.
