Hi
I have installed vray 2.40.04 on 3ds Max 2014 SP2. And when i use Vray RT on active shade, i put a Vray dome light in, (active shade works fine) then i add a vray hdr map in the material editor, and drag it over to the Texture slot on the vray dome light, the image goes black, ive pumped up the intensity of the light and material thinking maybe it was just dark, then i changed from a vray camera to a regular max camera and no change, has anyone got any ideas? Is it something im doing?
thanks
Rob
