Vray RT render problem
After I select Vray RT & render it, the screen become black color.No running…
I’m using 3ds max2013, Vray 2.0 SP3, windows 7 64 bits.
Anybody know about it, please…
**refer to the attachment file**
http://www.picresize.com/popup.html?images/rsz\_capture.jpg
help my…thanks:-(
I can’t see the picture…
Att picture
http://www.flickr.com/photos/83210361@N04/8102467328/in/photostream
Thanks…
“Hold your clicks a moment please…
Flickr has the hiccups. We’re looking into the problem right now.”
i not really understand,how to solve it? is it windows blocked??
First of all, check if you have the V-Ray RT render server running - you should have in task manager a process named vray.exe - do you see it? If not, try running the RT server manually from the Start menu.
hi, please help me check is this the problem you mention ??
http://www.flickr.com/photos/83210361@N04/8112074321/
Unfortunately still can’t see the image… same error as before. You can email us to vray@chaosgroup.com and our support guys will try to help you out.
