Vray Scene Converter - Corona Material Error
So I’m trying to convert a Corona Material to Vray using the Vray Scene Converter and can’t get anywhere because I always get this error
This is probably something simple I am doing wrong, but I don’t understand scripts very well so I can’t figure it out.
You will need to install Corona for the conversion to work. The demo version should work fine, even if it’s expired.
I have the Alpha v6 installed but I guess I need the latest version of Corona?
Yes, you probably need a newer version.
I was trying to convert some Corona materials to Vray and I was wondering why the Vray scene converter didn’t work. It’s when I did a search in the forum that I saw this thread and learned that I actually have to have Corona installed for it to work properly. Important piece of information that doesn’t appear to be included in the help page on Vray scene converter. As a suggestion maybe it will be helpful to add it there too. :slight_smile:
