Hello, I’ve encountered a bug where the VRaySceneConverter utility will crash completely if it encounters a CoronaNormalMap node with a map in its “Additional bump” slot. This can easily be tested in a simple scene, I attached a screenshot of the simplest shader structure to recreate this.
I can confirm this is reproducible with 5.00.04, however, I am not able to reproduce it with the latest V-Ray 5 for 3ds Max, update 1.2 version - issue seems to be resolved. For what it’s worth, can you try updating as already suggested and see if everything is okay.
