Vray Scene converter in 2009
Does it work?
Because the last X amount of times i’ve tried it, it’s always failed?
I remember having to change the code for models imported from Revit files, but i’m just trying to convert a simple downloaded model which has standard Raytrace textures…
I can send the file if needed, but it’s not worked for me in ages now, only with Max 2009…
Thanks in advance as always!
How does it fail?
Ah; change line 105 to
if (r.texmap_reflection!=undefined) then (
Just a question, without have taken a look at the MAXScript converter…
Isn’t there another bug on line ‘110’ - a forgotten ‘n’ in ‘transparency’ - or is the transparency-setting in the origMtl variable working correct?
There is no bug there, the script is correct. The actual parameter name in the Raytrace material is misspelled.
Ah okay. Thank you for the info.
I am also getting this error…
unable to convert :[color 17 17 17 0] to type :float
tcolor.color=(color (1.0-orig_mtl.refr_color) (1.0-orig_mtl.refr_color) (1.0-orig_mtl.refr_color))
Any suggestions ?
Regards,
Mike
It should read something like:tcolor.color=(color (1.0-orig_mtl.refr_color.r) (1.0-orig_mtl.refr_color.g) (1.0-orig_mtl.refr_color.b))
Thanks for the quick response !
Regards,
Mike
Script
Can some share this working script?
