I dont know if this is the right section for this post.. whenever i use vray scene convert option to convert my standard material to vray, all standard material convert but hilight glossiness values becomes 0.466. i want this to remain default.
Yes. I’ve found this annoying too - I never use highlight glossiness normally. You could use VMC to change all values globally I guess.
What is VMC? i am not aware of this option, in which section is it available?
ANy solution of this from Vlado?
Very annoying indeed, but it’s also annoying to use VMC IMO.
Yes, but quite an easy workaround until things (hopefully) get sorted out.
