Vray scene import crashes in UE 4.23.1 with latest build
We are trying to import a vrscene file into unreal using the latest vray plugin build 4.3 and we are consistently getting a crash showing the attached error. We have tried to remove all materials and lights as well as using a blank project file and the error still persists. Any idea what could be causing this problem?
Thanks!
Hi, tmbarker531
Sorry for the late reply.
Have you tried to to import the same vrscene with a previous build? Does it happen with a specific or with any vrscene? Can you please send us crash logs from PROJECT_NAME/Saved/Crashes and Logs folders and/or the problematic vrscene?
Alexander
I am having the same issue. I have attached my logs. Original scene created in 3ds Max 2020.2 with V-Ray Next 2.1. Just installed V-Ray for Unreal 2.4. Using Unreal 4.23.
JCI_IBS_2.txt (87.1 KB)
JCI_IBS_2_2.txt (71.3 KB)
Hi, jcox_hamilton
Thank you for the logs. I have logged the crash and will try to fix it for the next release. It looks like there is a issue with some of the geometry in the vrscene. There is somewhere in the scene mesh/meshes with no face normals information and that causes a crash. Can you please send the max file and/or the vrscene at support@chaosgroup.com ?
Alexander
