i have exported a huge Bofrost mesh sequence as vRay Scene.
When i import the sequence through the szene manager only one frame get rendered.
Is there an option I need to change that the whole sequence get rendered?
Make sure that you have done “Compute and Cache to Disk” for your simulation. Before exporting the .vrscene file, make sure that you have set the correct animation range. exporting a .vrscene file on a simpler new scene and report to us with your results.
