I was very impressed by the works of Dieter (ISO surface) Plugin. and that let to an idea of alos getting to work with the sdk to builp some plugins for vray.
Now i have knowledge of programming, but it’s been a while thus it means it will take some time to get going
But well in the end i hope to create some plugin or something.
Now i will be strating with the examples that have been included with the SDK. (by advice of dieter) hehe
Then i’ll be planning my project.
On idea is the create a plugin for Vray that will handle Relief mapping, more info is found at : Manuel's Relief Texture Mapping Page
But this is just an idea. and i’m hopoing to find more ideas on project that would be usefull. Thus i would like to ask all you vray guys if you have any ideas for this subject?
Also and usggestion on workflow would be awsome. but ideas are most welcome!
At the risk of creating a wishlist the size of the wishlist thread…what is possible in terms of SDK development??? For example, could one implement barn-doors on a vray light?
The V-Ray SDK allows you to code 3dsmax plugins (cameras/materials/textures/lights) that take advantage of the V-Ray API directly (e.g. trace rays, generate geometry or something else). In addition, the SDK allows you to replace almost any part of the rendering engine with your own implementation (e.g. you can implement a different image sampling method, or a different GI engine, or a different raytrace acceleration structure etc).
barn doors could be scripted.
I had an attempt the last time the thread on them was on, but found difficulties due to the light creation phase.
Will try again soon…
Great to hear there’s some interest in shuttering the vray light! I imagine that the ability to ‘cut’ the light to a specific focus might even be able to speed up render times, if you could rig it so the light doesn’t have to trace the rays that are beyond the given shutter angle…?
