I think it would be fine to have a map with a light energy multiplier, in which you can put a new map. So the picture in the selfillu slot behaves a bit like an HDRI.
Reason is, that if you have a bitmap (or procedual) in your selfillu slot and you want it to shine stronger than it can shine when selfillu is set to 100.
Like an HDRI, that it´s range reaches above the white.
Or if you set the multipier to zero that it does not light at all, but behaves like selfilluminating with normal scanline.
A blur spinner for the HDRI Map would be nice too.
Schnupps
