Vray serial number?
Any idea where I can find it?
V-Ray itself does not have a serial number, but the dongle does. One way to see it is from the WIBU-KEY applet in the Control Panel. When you open that, you should see a tab called “Contents”, on the left side of which there should be a “WIBU-BOX Tree” section. Under the USB branch in the tree you should see the serial number of your dongle.
seems to appear here too: http://localhost:30304/getstatus
Yes; however this will only work if you have the updated version from V-Ray RT installed.
