Vray settings - random change
Hello all,
Have a curious problem. Been exchanging some MAX scenes with my colleagues.
I have Vray SP4 installed. I archived the scene with textures and paased it to them. When they opened the scene, the settigns were setup differently
Examples:
- clamp outpud checkbox was on not off
- irrad map was set to medium animation instead of medium
- irradiation settings were 75/60 instead of 60/40
- global subdivs were reset from 24 to 18!!
etc.
I have to emphasize here that this is not the case of someone using a dodgy vray version!!! I know that some warez monkeys used to post here on the vray free thread some time ago that the settings r reset to default BUT i repeat this is not the case!!!
Could there be some issues between the vray versions possibly? Such as in the case where i would be using SP4 and them SP3?
Thanks a lot for any help.
Best regards
Curious problem solved…the files settigns have been tweaked by someone on the other side…:roll:
Glad that it’s sorted out now :slight_smile:
