I have problem with Vray interactive. It’s very slow for stop. I lost about 3-5 mins with every scene when click Stop interactive mode. It happens with vray next and 3.6 too.
My PC is dual 2670 v0. Is it problem?
I get this happening too, especially on our larger scenes.
Could you share the vraylog.txt file from one session with such slow stop ? Or even better - a scene that reproduces it so we can check what is going on ?
Also - do you have many proxies in the scene and maybe some of them instanced with VRayInstancer or with plugins like ForestPack?
Yavor
Yes, this usually happens when I have a lot of ForestPack proxies in my scene.
For the proxies case here is a possible workaround:
Thank you and where i can find vraylog.txt?
It happens with all case. Interior without forest or Vrayinstancer…etc. I think it’s problems of vray or my hardware, not my scene.
The vraylog.txt is located by default in your temp folder - write %temp% in the address bar in windows explorer.
[2018/Aug/3|07:57:33] Compiled with Microsoft Visual C++ compiler, version 19.12
[2018/Aug/3|07:57:33] Host is 3ds Max, version 19
[2018/Aug/3|07:57:33] V-Ray DLL version is 4.01.03
[2018/Aug/3|07:57:38] Constructor entered.
[2018/Aug/3|07:57:38] Setting default filter kernel.
[2018/Aug/3|07:57:38] Constructor done.
[2018/Aug/3|07:58:09] Resetting VRender.
[2018/Aug/3|07:58:09] Setting default filter kernel.
It’s here ;).
The log gets overwritten every time you start Max - so could you open a problem scene, start IPR, stop IPR, close Max and then get the log file ?
Do you have an email? It’s very long so i think i will send it by email.
You can zip it and it should compress very well. You can mail it to me at yavor.rubenov at chaosgroup.com
Thank you i sent it to your email.
Thank you for the log.
So far I can’t seem to find a problem in the log - it looks like you start IPR at 17:33:17, do a bunch of changes and then stop at 17:39:55, V-Ray does its cleanup and at 17:39:58 it is done ?
It still happend with me. I will try test with more file and report with you. Thanks
