vray spawner problem
I’m having troubles starting the vray spawner with viz 2008. I’ve ran vray jobs through backburner; I’ve created the vrayspawner.ini file in the root folder of viz 2008 (pointing the service to the 3dsviz.exe file), but the spawner is still opening and closing.
I’ve attached my log file in the hopes it sheds some light on whats happening. Any help would be great - I’ve spent the better part of this week trying to get this resolved, and deadlines are approaching soon.
0: [2008/Jan/11|12:02:46] ========================== Starting new session ==========================
1: [2008/Jan/11|12:03:01] Got this module name: C:\Program Files\Autodesk\VIZ2008\vrayspawner90.exe
2: [2008/Jan/11|12:03:01] Got this INI file name: C:\Program Files\Autodesk\VIZ2008\VRaySpawner.ini
3: [2008/Jan/11|12:03:01] Reading settings from INI file: “C:\Program Files\Autodesk\VIZ2008\VRaySpawner.ini”
4: [2008/Jan/11|12:03:01] --
5: [2008/Jan/11|12:03:01] Dumping current settings…
6: [2008/Jan/11|12:03:01] VRaySpawner temp dir: “”
7: [2008/Jan/11|12:03:01] Application name (MAX/VIZ): “<C:\Program Files\Autodesk\VIZ2008\3dsviz.exe>”
8: [2008/Jan/11|12:03:01] --
9: [2008/Jan/11|12:03:01] Process id is 3180 (0xc6c)
10: [2008/Jan/11|12:03:01] *** ALERT! Error opening file “<C:\Program Files\Autodesk\VIZ2008\vraydummy90.xml” for reading
11: [2008/Jan/11|12:03:01] Exiting our service due to errors
12: [2008/Jan/11|12:03:02] ========================== Ending session ==========================
thanks to anyone who can help!
Matt
What operating system are you using? Also, is the vraydummy90.xml file really there?
Vlado -
Thanks for getting back - we’re using windows xp 32bit - and yes, the vraydummy90.xml file is there --
Matt
