Hi
As I recall this was an issue back in 3.7, which was once corrected. Now I still have this problem.
Using twice or more, the same material, with different projection offset, only renders out the last material. To fix that, we must make a copy of the same material and attach it to each different material tag.
Is there a reason why this bug is still present in v5?
(first cube uses the same material in each tag, the second uses the original and copy)
Rafal
