vray sun and sketchup sun
I’m having a problem coordinating this 2 options.
I enable sun in sketchup and I check the “use sun for shading” options in shadow setting.
But when I render it using MADO visopt, the sun in render didn’t came up the same orientation as sun and shadows settings in sketchup. thanks for any help in advance.
Re: vray sun and sketchup sun
This sounds like the Sun re-set bug (which is fixed in SR1 !!!)
In the environment - GI (Skylight) roll-out
untick “Override Sun’s parameters”, hit ‘apply’ and then tick it again, and hit ‘apply’ again, that usually does the trick.
(In other words you have to completely re-set this option after any changes in sketchup)
David
or just hit update under the preview square in that same window
Thanks guys.
Dcauldwell your right.. :wink:
