Vray swatches gone in 6.2 in Material Editor
Hi
I installed 6.2 today.
About 2-3 hours later - suddenly the swatches in my Material Editor are gone. I reset the the slots - nothing. I restarted 3ds max - nothing.
My system :
3ds max 2021
AMD 32/64 cores
128 gigs RAM
2X RTX3090
Windows 10
Hey @nirsul
This has been fixed and announced here, so please make sure to download the latest build directly from our download page - Download | My Chaos
Hasn’t fixed it at all, not for me, I now have this issue after all previous installs ‘locked’ 3D Max 2023 interface with no Material Editor problems, UNTIL now I have no materials in Max, I installed the latest version,
To make this update work
I had to uninstall VRay
Uninstall Max
Reinstall Max
Reinstall VRay
Leave Max open for 40 mins, while Max/Vray sorted out their differences to make this update work
and now, no usable Material Editor !
Until I remembered some advice to tick 3D Max Material Switches (which was a workaround for the previous flaky update) the scene loaded with a default pallete, no scene materials, until I loaded them back in !
yeah installing 6.2 has introduced this issue for people in our team which is getting quite annoying.
Every time we load a scene, all swatches are grey.
The workaround we found is to switch the material editor render in the common tab to scanline, then back vray 6.2, then reset the material editor slots to get them back.
What is the entire version number you see for vray? Does it end in 0 or 1 ?
If 0 you need the updated version. It depends on when you downloaded 6.2
So let me get this straight, there are TWO 6.2 releases with the exact same file name and number on the download page? What are you friggen doing Chaos, far out.
Yes we had 6.2 with the phantom 0 Jesus Christ
Yeah, pretty much. Should have been called 6.2.1 of you ask me. Software has had the Major.Minor.Bugfix release numbering scheme for decades.
I don’t think the ambiguity was worth not fully bumping the version number, personally. but I guess it made sense to somebody. At least the last digit is different.
Well yeah, if its v62001, then you know, NAME THE FILE THAT. If we experience a bug like this, the first thing we’ll always do is go to the download page to see if there’s a new version.
In this derp case, there wasn’t a new file version (but there secretly was, shhh)
To be fair , the download page will show the new update date which is different from the initial release , and the link in the first reply from @nikoleta.garkova ​ will show that there was a new update for 6.2 which will fix this issue and few others.
with that being said , there should have been more clear announcement for users who aren’t active here in the forums and downloaded the earlier version.
@yavor.rubenov ​ Said that there will be a notification in the VFB for future so this hopefully won’t happen again . .
https://forums.chaos.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-problems/1196353-materior-browser?p=1197764#post1197764
In short - my mistake. Sorry about the confusion it caused.
Hello. We too are having issues with materials not showing up in the material editor on all workstations. We are using the version you’ve linked to. Does the new update released today fix this? It is not mentioned in the bug fix list.
After installing the latest fix, I think the problem went away for us.
