When using vray toon the z-depth render elements is also affected. This is not good(at least for me). Is there a way to ignore toon render on the z-depth render element?
This is actually in our list of future V-Ray Toon improvements. In the meantime you can try the workaround provided here:
http://forums.chaosgroup.com/showthread.php?71806-Vray-toon-and-zdepth&p=574659#post574659
I’m still getting this issue in Vray Next, in Maya 2018. Is there a fix or workaround that’d work in Maya?
Thanks!
Same problem here with V-Ray 7 and Max 2023. Is this still being looked at?
The issue is logged (internal bug-tracker: VMAYA-3168 ), but since it is rarely reported it’s not a priority.
