Vray Toon as extra text or separate render pass.
Right now I have an animation where I’m rendering the objects with an “x-ray” effect and using the VrayToon effect to get a nice outline of the objects. At the moment I have to render the animation twice - once without the effect active and a second time with the effect active so I can get the VrayAtmosphere pass for the lines. Would be great if I didn’t have to do this :slight_smile:
+1 Would be very useful
Actually this was requested before, but seems to be somewhere down of the list. I will try to bump-up it’s priority.
+1 on this ! :slight_smile: we dropped the idea of outlines due duble render
edit: did you ever tried to use a ExtraTex_map with a Dirt map as a material in passes? if you play with the settings in a dirt map…you can achuve something that might help…
Thanks.. any chance it could be done by tomorrow? :smile:
I don’t know how much time will take this implementation and I can’t guarantee this will be fixed so soon. Let me check that with our dev team.
I’d vote fo this feature too!
We will try to make it for the next official SP release.
Wow, great ! I think I asked that more than five years ago
Good things come to those who wait. :slight_smile:
Thanks a lot, it would be great !
Any news regarding this feature? It would greatly speed up my workflow if I could render the toon as an element and not in the RGB.
3.6 is out but reading the release note it doesn’t seem that this feature was implemented.
This feature is available since 3.50.02 release. You can see it in the log:
(*) VRayToon: Ability to store the toon outlines in a separate render element;
Ok, yes. I thought the OP wanted the Toon effect to appear ONLY as a render element without affecting the beauty pass.
Correct. That’s what I’m after as well. Seems like it “should be easy enough”, but those are probably every developers most hated words.
Either it’s tricky to implement or it keeps falling at the bottom of the todo list for whatever reason :slight_smile:
Anyway, having those environment effects like toon and aerial perspective only as a render element makes much more sense for compositing.
Please Chaos. We need to be flexible. All the shiny effects need to be removed (meaning : added separately) beacause these kind of effects (fog, toon, glow etc.) are often modified to fit clients need. This is what we should expect from a professionnal software.
As much as I love VRay, there are some issues like this one that are dragging behind for no reason. I asked about that a long long time ago and tought I was the only one. But now I see a lot of other users asking the same thing.
Baking them in the beauty is making them useless for most of us. And we are not using them for that reason…
We also have this request for the toon not to affect the RGB in our “to do” list. But I can’t provide a time frame for its implementation.
Thanks ! I realise that my previous message was a bit aggressive. It’s really not my intention, just to point out that some great addition you make to the engine are unusable in some porductions pipelines because it misses a little checkbox somewhere.
That being said, every effect should have an “affect RGB” checkbox somewhere that we could turn off and obviously, it should’t affect other render elements but instead have his dedicated render element. That’s the compositing dream :slight_smile:
We’ll keep that in mind. Thank you for your feedback.
