vray triplanar with alembic animation
Hello! I have some issues with vray triplanar texture. I have got an alembic animation (ground fracture). When I apply vray triplanar texture to my moving geometry pieces it behaves like static texture, I mean the objects are moving but triplanar texture stays like not connected to the objects.
Here is the example:
thats the nature of a projection.. :smile:
i you have animated objects you need to bake the texture…
Yep. The alembic cache is like a giant deformation - it’s doing vertex animation instead of doing individual objects with animation on their position, rotation and scale which would be fine with triplanar. One of the main reason alembic works between programs though is that it throws away all animation controllers (which can work differently between programs) and only moving the vertices.
Okay! I think I got it. Thanks for your replies. Now I am going to find out how to bake those triplanars..
joconnell: While that may be true for this case, alembic does support object transformation, as well as deformation.
Good to know, I only get the shitty export in max which doesn’t allow me many options. I love these universal interchange formats which have two slightly different standards and varying degrees of support depending on which package you work in :smile:
In Maya they is an option called “Texture reference object” where you choose a frame, do your projection, and Maya/VRay will render automatically your projection with not “sliding effect” (it will always render the texture as the frame you choose).
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Maya/files/Asts-Create-Texture-Reference-Object\-\-htm.html
I tried texture referenced object, but did not realize how connect it with vray triplanar texture. So, “sliding effect” was still there.
If you have sliding effect with a texture reference object + vray triplanar, this is not normal and this is a bug.
Does the same setup with Maya Triplanar Projection and Maya Software Renderer gives the same sliding effect?
