Vray user interface lost...
played a little bit with custom ui and defaults switcher, now my ui is completely messed, for example the context menu entry “vray properties” has gone. I can´t find this one (like customize - vray commands - show last vrayframebuffer)
Anybody know where can i reload the original menu?
Matthias
ha, sorry, found it (show vray properties) - but still any way to reset to default?
if you cant load the default ui through the max customization menu, then you can delete the 3dsmax.ini file and max will create one from scratch at startup.
