vray very slow
Hi all,
Been having some really weird issues with using 2018 and vray 3.60.03. Very slow to move around and do things in the scene. Also when I do render something I don’t see anything updating the vfb, ie no buckets moving. I included a txt file and the error message that I got from the last crash.
Anyone else running into this?
Alex
vraylog.txt (95.6 KB)
Alex, I can see from the log that you are using IPR. Have you tried with bucket rendering?
Please send me the scene at my email.
I did not try that Chris. I will look into that but it’s just a weird file. Its only 6mb and it takes a long time to save and open. Peter, I just sent you a zip file with everything.
Are you using RT GPU as Active Shade (IPR) when this is happening? Because there is a denoiser added and it switches automatically to the denoised result channel (effectsResult) while rendering and since it does denoising periodically (after some passes are done) you see the image updating only then.
About the crash - I will need some more reproduce steps, since it seems very stable here. Can you check if there is a 3ds max/V-Ray dump file in the %temp% folder (3dsmax_minidump.dmp and/or vray.dmp)?
Take a look here - V-Ray 3.6 VFB hangs - Issues - Chaos Forum
