Vray VFB
I’m trying to render and save an image in Vray. However, I noticed that when I save my image, it looks dark compared to what I see in the frame buffer? What has changed? I used to be able to save my passes as individual tifs and they would look like the frame buffer render. I also noticed that when I add a layer it doesn’t list all the layers in the frame buffer. What am I missing.
Most likely this.
You’ve probably hidden the menu. There’s a little handle on top of the Properties panel, drag it downward.
Yes… found that. Still not saving my rgb channel correctly. Thoughts?
Send the scene so we can take a look.
