Hello doing a sim in Phoenix in maya and rendering in vray / houdini, getting some lines in the render I don’t see this in Maya in the preview. any ideas? happening on several sims
using houdini 18.5.351
vray 5.0050 build 11723
Phoenix for maya 2020 v4.30.00 build 20200912
Hey @Ghost3d ,
Any chance for a scene file so we could try to reproduce this here ?
If not:
1. Are you exporting AUR or VDBs ?
2. Could you please try disabling the Volume Grid Shader → Smoke tab → Volume Light Cache (Enable) and Smoke tab → Light Scattering (Type) → set to Disable ?
3. Could you please try inreasing and/or decreasing the Voulume Grid Shader → Rendering tab → Step % and Shadow Step % parameters - e.g. try increasing them to 900/2000 to see if anything changes.
4. Could you please try disabling Voulume Grid Shader → Rendering tab → Optimize Big Volumetric Grids
5. Finally, could you please try enabling V-Ray Renderer ROP → Renderer → Objects → Volumetrics → Probabilistic Volumetrics
To be fair, I’m shooting in the dark with suggestions that might help isolate the issue.
Best regards!
thank you ill give this a try . I am caching AUR files
