Vray Volume Material?
I can’t see Vray Volume material - how do we handle now specified fog / volumetrics for different geometry objects?
Best
Rafal
You could use multiple fog objects and/or gizmos. This one has 2 separate fog objects each with 1 gizmo, so that you can have different look for each fog volume. If the fog look is going to be the same overall, you could simply use 1 fog object and as many gizmos as you need for the shot.
