We have recently upgraded from VIZ2007 to VIZ2008. We have been using the latest release of vray within VIZ2007 which works a treat. However, it doesnt appear to be compatible with the new release of VIZ (2008)
Can anyone shed any light on this compatibility issue?
Is it possible to have both versions of vray working with their respective versions of viz? i.e VIZ07 with vray1.5(max8) & VIZ08 with vray1.5(max9)?Yep, you should be able to do that.
Yes, the max 9 version works with viz 2008, and you can have Vray installed for both Viz 2007 and Viz 2008 at the same time no problems.
That said - Viz 2008 is probably the worst release of Viz I’ve ever encountered… File Link seems to be broken (I can’t link anything from ADT) and the new mental ray licensing scheme is terrible. They’re definately trying to push everyone to max.
We are using 3 licences Viz2007 which all going to update to Viz2008.
>> So, as it has been said here, we gonna dowload the correspondant version of vray for our new version of viz without problem and costs.
We are intending to buy a licence of Max 9.
>> As, when we install Vray on a PC (rendernode or not) we have to specify the VizPlugins folder or MAxPlugins folder, how will it be possible to use the Distributed Rendering altenatively from max and vray ?
In the same way, a backburner job sending from max will be detect vray on a VizVray installed rendernode ?
Sorry for my difficult english and thanks for your answer.
Arno
I’ve tried to reinstall vray RC3 for max8 on a rendernode which already run with viz2007+vrayRC3.
The installer ask me to desintall the previous version of the plug…
When it says that “The older version must be uninstalled…” etc, click OK, but when the uninstaller itself starts, select Cancel. Then go on with the installation.
We are encountering the same problems with the file link for VIZ 2008. The link to the patch mentioned on earlier in this thread fixes this bug for legacy max files that were file linked for max files saved in earlier versions. We are having the same problem with the file link for current files originally created in VIZ 2008. It goes through the motions of opening up then…nothing!!! very frustrating as we have many models file linked from ADT and refernced into VIZ for final renders. Has anyone experienced similar problems with the new release of VIZ. Any ideas how to fix this bug??
I’ve had similar problems (i.e. appears to update linked file and then nothing) and was able to get around it by doing a selective reload. Choose “selected in list” and just make sure everything is selected. This works great for anything thats already in the scene but haven’t found a solution for anything that’s new.
Thanks for the info and tip dlparisi. It does appear that there may be a fundamental problem with the file link at the mo in VIZ08 and their doesn’t appear to be any patches available to sort the problem.
