Vray xgen chair
Is there a way to apply vray xgen hair? I have it on auto load in the plugin manager but I don’t see it anywhere? I’ve seen the two hair shaders that’s it?
First, you should create xgen description for the object then you can assign VRayHair3Mtl or VRayHairNextMtl to the xgen hair. You should be able to create a xgen description through the XGen tab.
