Hi guys,
this might be a silly question , but we upgraded to Vray2, had the Beta version before and worked fine, but now it seems that there´s a problem because the bitmaps are not rendered when using RT, meaning that he object is black when a simple texture is applied. We are using Maya 2011. Am I missing something ?
Thanks.
A-
Have you looked at the log of the VRay standalone server (vray.exe)?
Are there any errors there?
do you mean the Maya´s output window ? No errors in there .
Alex.
Hi T,
just uninstalled “Maxwell Fire” and also old Vray for Max version that we has on the same machine and now works all fine !!!
Thanks,
Alex.
Hm, odd but glad that it’s working now.
I have a similar problem:
When I DR with the “Launch Render Slave” on each rendermachine, all is fine and all textures get found.
BUT when I use the vr-renderslave as a service, it renders but all imagetextures (and GI-stuff) are missing. (The renderslave-machine logs in with my useraccount automatically, so all networkdrives are mounted)
Where do I find a logfile from the renderslaveservice?
OK, I can DR-render with placing the “launch render slave” in the autostart-folder, but a service woud be more elegant.
BTW: If I render via backburner (each machine a single frame), all is fine too.
Thanks in advance,
Marco
Did you set up the service to run with a proper user account, instead of the default system account?
