We seem to have lost the ability to use <frameNum> in the VFB for Background (or As Foreground) images. Anyone else seeing this?
Before I could display the current frame of a sequence in the Background layer of the VFB using MyFile<frameNum>.png to load MyFile0003.png on frame 3 of the animation.
It works fine on my end, tested with the latest official build (6.00.08 ). Are you sure there isn’t a typo on your end?
It’s weird. It is working now, without having changed the entry in the file name setting. Must have been some transient issue. If I can reproduce it I will let you know.
it was working in a nightly build from the 11th I think. Then after upgrading to the official build it didn’t work at first. But now it is. Go figure.
