VRay6 // Sage Object + VRay Camera + Spherical Camera = Nope
We have found a bug that unfortunately forces us to switch back to the VRay5 version. If the camera is set to Spherical and you use a Stage object then it can happen that the VRay Cameratag is not used when changing the image. Here is an example file that shows the problem:
It is not caused by the Python script, it happens even if the cameras are keyed normally.​
The error only occurs in VRay6. In VRay5 everything still works fine.
Both versions were tested on the S26/Windows.
Stage_Spherical.zip (65 KB)
Hi @Doger , this seems to be a regression on our side. I have logged a bug for this (VC4D-1569) and we will be investigating it shortly. Thanks for the report and sorry for the inconvenience.
Hi @deyan.hadzhiev ,
do you have any progress on this issue?
Hey, Doger,
The ticket is opened and is a work in progress. There is no specific timeline for that, but I guess it will be fixed soon.
Cheers,
Hello @Doger ,
As you might have seen in the Announcements post, this bug is now fixed and the fix is available in the hotfix that we released last week. You can download and install it from here. Thanks.
