Vray7 Hotfix1 - VFB Adjustments not saving through VFB
So been doing some tests on my end. Seem if I make adjustments with vfb and manually save image the adjustments are not quite accurate. When I save through output of VFB it works fine.
Another thing I noticed. If I have VFB adjustments and save the final as an output through vfb while having “Save VFB color corrections to render elements” unchecked, it still saves them to the rgb passes. I thought in the past the only time those adjustments ever got applied was only with this checkbox checked?
Seems some inconsistent outputs are happening now with color corrects and save files.
EDIT: Did some more testing and now seems to be working fine, not sure if its due to having a max file with vray 6 settings and now swtiching to 7. However, the issue 2 with the VFB adjustments saving into RBG files is still accurate and is a problem?
You are probably confusing the option with the V-Ray Raw Image option, named “Save VFB color corrections to RGB channel”. The one in the “Separate render channels” concerns saving color corrections in the render elements. Otherwise, saving through the Separate render channels (through 3ds Max) has always worked like that (saving CCs to the RGB).
Hmm, maybe you are correct Hermit. I will do some more tests on my end to research what is happening. Thanks sir!
