VrayBitmap does not update image sequence frames in viewport
Just Like the title says. I can’t get the vraybitmap sequence to update on a frame by frame basis in the viewport. It just sits on one frame. Am I doing something wrong or is this a bug?
Thanks!
Nickolay
edit: it updates in the material editor though… strange.
Hi @nickolay411
That’s true, I’ve managed to reproduce this and have logged it into our internal bug-tracking system (ID number: VMAX-10433) for developer investigation. Thanks for the pointer! Will let you know when there is any update on the matter.
Thank you Nikoleta!
I seem to recall VRayHDRI always worked like this too.
Work around is to use a Max Shell material and set the render to be your normal VRayMtl, but set the display to be a basic Standard or a physical material with a standard Max Bitmap node in the diffuse slot.
FYI this has been resolved and will be implemented in a future update.
Thanks for the update. This is great news. All the little things add up.
Great news! Thank you!
nice i came here to report this lol!
So, this wasn’t implemented yet I guess.
