VRayBlendMtl - go to parent CRASH
I’m using vray 1.5 rc3 64 / max 9 64, and when I create a VRayBlendMtl I have problems when I hit the upload to parent button. Max crashes everytime and it doesn’t matter what file I’m in. Help please.
Do you mean “go to parent”
Works fine here.. although 32bit
yes, :sweat_smile:
I will try to see if I can reproduce that here.
thank you.
Unfortunately I don’t get this here in my simple tess. If you have a scene where this happens you can email it to me at vlado@chaosgroup.com as there may be something else in the scene causing the problem.
Thanks Vlado, but I get the same results no matter which scene I have open. It even happens when it’s a new scene. I went into the paper model scene that I posted here a while back. It has a VRayBlndMtl, which never caused the crash when I was working on it a couple of weeks back.
paper model scene (I’ll email you the max file)
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=18072
I would suggest a simple uninstall - reinstall of vray. Does it only happen with the vrayblendmtl ?
The problem is solved. I went into a file that was created on January 28th with a vrayblndmtl that worked fine at the time. Of course it crashed, so I did a system restore back to that point and everything is working now. :roll: Thanks for your willingness to help guys.
haha weird ok cool.
I would have imagine a vray reinstall would ahve done the same thing… maybe.
Ahh well … good fix
