VRayCam to Standardcam (what settings divider?)
Question…If I need to use stadard max cam instead of vraycam and I alrady have all lights and exposure set upe for vraycam. What divider I need to use for vraylights (dome light when using or sky) (for it’s intensity) to get same exposure with standard max camera?
It’s going to change depending on the iso, fstop and shutter speed - might be an idea to sample a pixel and get its rgb value / real pixel value from the vray cam, then switch to a normal cam and sample the same pixel, then it’s straight division to get the factor you need to put in your colour mapping.
