VrayCameraLister has been modified.
I was uninstalling and reinstalling vray because of this thread: workstation unusable while rendering - was much better in the past. - V-Ray for 3ds Max :: Issues - Chaos Forum
And now I’m getting this error the whole time:
MAXScript
The file ‘VRay-vrayCameraLister.mcr’ has been modified outside the application. Should it be reloaded?
&Yes &No
Maybe there was some leftover files from the previous installation. Could you uninstall, clean the folders and reinstall?
I tried this, uninstalled Vray and then in AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU\usermacros removed all vray scripts. Then reinstalled. Still the same problem. Are there any other files that need to be removed in certain folders? This is very annoying, it keeps popping up. I don’t even use the script.
Try removing the registry entries in the Registry editor prior to installing again. The location should be here: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Win dows\CurrentVersion\Uninstall
