I’m not finding the carpaint2 shader that intuitive. I’ve made sure the scene scale is 1cm. The results I’m getting are ok but there is a lot of room for improvement. Problem is that I cannot seem to reduce the actual flake size effectively. If I do repeating patterns start appearing and I have to raise the fake map size to 8192 which really slows down rendering.
At the moment I get this result. The metal flakes seem way too big when the camera is close up and they don’t seem to end on just the hi-lighted areas. I’ve increased the flake orientation tail falloff.
Any help or advice really appreciated.
I’m also hoping to add the small circular scratches to this shader as well.
