Hello, I tried to animate a VrayClipper in Vantage, but it doesn’t work. I tried 3dsmax’s Slice modifier, but it doesn’t work. To date, is there a command I can use in Vantage to override the modifiers mentioned?
thanks for help
Hi radiosity1980,
VRayClipper is currently not supported. However the Slice modifier should work correctly in Live link and ‘Render animation with Chaos Vantage’ and not when you export the animation to a vrscene. Can you try with the ‘Render animation with Chaos Vantage’ and see if it works for you?
Alexander
I tried to use the slice modifier, but it doesn’t work
Filippo
Hi Filippo,
In my test an animated slice modifier works through ‘Render animation with Chaos Vantage’. Can you please send a scene to test?
Alexander
surely. Which email address should I send the file to?
Filippo
You could use the chaos help center here https://support.chaos.com/ to send the scene.
Alexander
done! but,
I also tried with a simple box with the slice applied, but it doesn’t work. Maybe I am doing something wrong?
Thanks for help
Filippo
Hi Filippo,
We received and examined the scene. All is working fine on our end: https://drive.google.com/uc?id=1KOPafSyFTtM7fte1AfvUXe7Cnlz\_vdUB. Can you please record your screen to see the steps you are doing?
Alexander
Hi Filippo,
Yes, deformable meshes (which the box is in your case) from .vrscene will not work with the current version of Vantage (1.8.1.). We plan to add support for deforming meshes for vrscenes and other supported formats later. We will notify you when they are implemented.
Alexander
