Hi I would like it if you could put the Use object material setting on the VRayClipper like in 3ds Max - V-Ray for 3ds Max
Use object material - When enabled, the clipper uses the material of each clipped object to fill in the resulting holes. When disabled, the material applied to the clipper object itself is used.
Thank you very much
Hi @giuseppe_uggeri
if you want to add different materials the the clipper object(s) simply apply the material you want to the corresponding clipping object.
You can even go a step further and use a single material applied to the V-Ray Clipper object and use the MultiSub texture to randomize the results
Hello @giuseppe_uggeri ,
Thank you for your feedback.
I have added a request for this in our internal system (ID: VC4D-1332). I will let you know if we have any updates on the matter.
Many thanks and good luck
Please note that with the latest stable build (which can be found here) our developers introduced the “Use Object Material” option for the V-Ray Clipper.
Keep in mind that currently there are some known issues with the texture mapping which we aim to fix in the future. Thank you.
Many thanks for the update
