I’ve always used invisible Vraylights with a Vraycolor alpha 0 set to a desired temp rather than a color, but in 3dsMax 2025, Vray 6 update 2.1 its an immediate crash. Color works OK, just not temperature. Can it be fixed?
Quick update - temperature works OK and crash avoided if I disable texmap preview in the VrayLight viewport roll-out. Just thought of that after posting, tried and it works.
Hi @smiff1000 ,
Thanks for flagging this - I am able to replicate the issue you’re describing and I’ve logged it in our internal bug-tracking system under VMAX-14149; will notify you as soon as we have updates on the matter.
The issue should be fixed in stable nightly 32635 (https://nightlies.chaos.com/#/vrayma…e_6.2/20240620). Sorry for the inconvenience.
Yavor
