Hello, i’m not sure if it’s the right forum to ask this question but we are adding the possibility to our artists to denoise image in comp using the amazing vraydenoiser node. But our pipeline is loading nuke gizmos, plugins from a network shared folder. Everything is working well except the vraydenoiser node that is outputting a blank error message when loaded from a shared path. When the path is local everything is working well.
To resume in the init.py if is local :
import nuke
nuke.pluginAddPath('C:/local_folder/VrayDenoiser')
works and we can use the node, but :
import nuke
nuke.pluginAddPath('//network_folder/VrayDenoiser')
When we create the node we have this error message :
We even tried to map the network path to a mapped drive same issue. We can’t install locally on every workstation and render farm the node since the pipeline dynamically load eveyrthing for the artist.
Thanks for your help. We are using nuke 13.0v4
