im exporting a model for a friend to use in maya… it comes in massive but a simple scale to 10% fixes it .. everything works apart from the AO maps… before he scales it it matches my test renders pretty closely… after scaling down , anything with vraydirt on looks wrong, like scale is too big.
triplanar works, scaling correctly with the vrscene, but dirt… nope!
its a pain cos i have to do any material tweaks..
Probably some kind of a scene unit mismatch. Anyway, the VRayDirt radius is in scene units so that’s why a simple scale won’t work. You can easily override the radius through the Override Snippet (VRayScene>Scene Overrides). To do that open the .vrscene in a text editor, find the Dirt map, and copy the plugin name and the parameters, which you wish to override. The snippet code should look something like this:
TexDirt Map__1@tex_0 {
radius=0.1;
thanks for the pointer.. be nice if there was a scripted tool which made a UI for all the editable parameters… having said that there are probably quite a few in a typical vrscene!
