VrayDirt + Regular Material = No AA
So I’m not sure if this is possible or not. I want to use VRay Dirt for a ground plane to create a nice generic shadow for elements setting on top of it. However I want to render the elements as normal. The problem seems that the VRay Dirt background doesn’t anitalias with the foreground object. Is there a switch I can turn on to get this to happen or is this just not possible?
Thanks.
can you post an image illustrating your problem?
