vraydirt+vraydisplacementMod = max crash
hi,
is it normal that max crashes, when i apply the vraydirtmat to the vraydisplacementMod??
I thought i could do some nice 3d-transitions between different objects. but this does not
seem to work. as soon as i hit the renderbutton, max says goodbye.
cheers, dirk
I guess that’s because that would cause a dependency loop. The dirt changes the mesh topology wich would in turn change the dirt. I gueess you’d have to bake th dirt into a texture.
Regards,
Thorsten
Yeah you got a chicken-or-egg thing going on there. Which does it calculate first? The Dirt depends on the geometry/displacement.
ok that makes sense, i already thought about this too. thanks for the replies.
cheers, dirk
