Is there VRayDirt for Rhino? If so where is it? If it’s not there why not and when will we get it?
Thanks for any info.
Never mind. I think I know. It’s under the material area when you load a the pre set texture maps to an object. At least I hope that’s it. I’ll have to play with it and see. ![]()
Looks like it doesn’t have the same options as the vraydirt that I see in all the documentation. I guess v-ray for Rhino gets a lot of the goodies left out.
Thanks for letting me know. So was I right, is it just applying the TexDirt via the diffuse layer? Thanks. Yeah, I’d like to play with it a bit to see what I can do with it. Thanks for your response.
Yes, you have to use the texDirt on the diffuse and I also use texDirt on the reflection layer to avoid reflection on the occluded area. That was the case on the dragon render.
Best
Thanks for you help.
