VrayDisplacementmod in one ID ??
There is a way to implement a VrayDisplacementmod a single id?
I have a Multi / Sub-Object but I only want to apply VrayDisplacementmod the “id” number 2. Is this possible without having to use Maps / Displace?
Regards.
if you select “use material” or whatever its called in the 3d displace options of the modifier (im rendering cant check) it will use the map in the material displace slot. this means you can have local control whilst using material ids. other than that.. not as far as i know, since material id, by definition, is a material thing/…
Wow, it works!
Took time trying to fix this but could not get it right.
Super gnu, thank you very much for your quick response.
Regards.
